I'm just curious would it be possible to swap a SRT gauge cluster for a standard Hemi cluster, do they have the same connections and be a basic plug and play?
yes. they all have the same connectorshey BB - can you hook from an srt into an se???
Does the SRT8 instrument panel have extra gauges such as Oil Pressure, Charging Status, etc? I have never been comfortable relying on idiot lites because when those come on, its usually too late.Why exactly do you want a SRT cluster? You can just get a graphics face for the standard gauges and they'll look exactly the same, just only go to 160 vs 180 and the RPM gauge will be a bit different.
I just noticed these available on ebay last night, previously I had only seen them for the 180mph SRT8 gauges but now for the 140 or 160 non SRT versions too.Why exactly do you want a SRT cluster? You can just get a graphics face for the standard gauges and they'll look exactly the same, just only go to 160 vs 180 and the RPM gauge will be a bit different.
The EVIC cluster (optional on R/T [160mph speedo]) has the 4 wheel TPMS, oil pressure, oil temp and trip computer. There are also all the screens to change headlight delays settings, Hill Start (stick), alarm settings, etc.Does the SRT8 instrument panel have extra gauges such as Oil Pressure, Charging Status, etc? I have never been comfortable relying on idiot lites because when those come on, its usually too late.
so my r/t has evic and buttons on the wheel and i can access everything but the 1/8mi, 1/4mi, g-force cornering,wich is on the srt evic... can i get those functions by swapping in an srt evic?????
yes the needles work fine. when you swap it out you won't have the compass display unless you can find somebody to enable it.please keep me informed if you get it working,im about ready to swap the srt gauge into my r/t...but i need to find one first..do the needles work??
The model / equipment sales codes / VIN are encoded in TIPM (power module in engine bay) and the IP cluster has encoding for what equipment / model as well as the PCM (engine module)Hi i own a 2009 charger se. Im about to buy a srt8 speedometer cluster and replace my old one with the srt8 but the only problem is will it be the same MPH if i go 25mph will it also go 25mph on the new cluster swap or do i have to reset it or flash it so it can read the car?
