1 - 12 of 12 Posts
Is there 20 people that would be interested in buying a hosingtech intake tube?
2018 Scat Pack Charger 11.995 first time out stock tune
The bellows disrupt the airflow or otherwise cause turbulence. I am running a smooth tube now. Thinking about getting in on this. The silicone reducer would help. Aftermarket CIA do have a smooth tube. Keeping stock box and running a silicone can't hurt. No dyno numbers but think if the bellows were smooth inside. Take your lid off and look down the hole into the bellows and think what the air would do if it was smooth.
I am using this right now. Seems to help me keep up with catless mids.
4 inch sanding disk wheel at lowest. Couple of hours and don't go to thin. Need coupler at the box still. You can find this and sanding wheel @ Lowest. Set you back no more than $20-25. Plumbing section the street elbow can be found in the black pipe. Lots of dust, but bore it out and you get what I have. Less restriction to turbulence. Good luck.
1 - 12 of 12 Posts
