1 - 3 of 3 Posts
Some kind soul has dented the area just behind the driver's door. Anyone have any ideas as to remove the interior side trim so the dent removal man can work on it?
you'll have to
*pull up door sill trim (access screws that hold the rear 1/4 trim)
*remove the rear seat bottom (it pulls straight up - takes some effort)
*remove rear seat backs (they overlap the rear 1/4 trim)
There's some button style retainers once you have the seats out of the way and then the interior trim pulls out - its held in with metal clips.
You can get the trim out of the way and leave the seat belt attached. Otherwise to remove the trim panel completely out, you have to unbolt the floor anchor bolt for the front seat belt.
Reactions: eddark
They might be able to pull the dent without removing the interior panel.
I had some dents removed in my roof and they used a glue puller device. They got the dents out 100% and never pulled the headliner or anything.
Reactions: eddark
1 - 3 of 3 Posts
