1 - 3 of 3 Posts
After a day of racing at the drag strip I noticed afterwards when I would slow down and start turning that my rear wheels would start acting up. It seems like one wheel is spinning faster/slower than the other causing the inside wheel to literally skip then lock up then skip n lock up, and this is only turning at maybe 5mph...is this my DIFF broke? Or jammed or something? Because when I drive straight line it doesn't screw up
sounds like the slip is gone in the limited slip. try back up and turning the wheel. maybe that will jostle it loose
I have had this happen
Years back after drag racing my blown Cobra all day I noticed exactly the same thing - like bang bang bang when turning. Let it cool down, do some tight turns, it should go away. Its Over heated, let me know, I'm confident you will be fine.
1 - 3 of 3 Posts
