I have a 2014 Dodge Challenger srt8 and I’m trying to figure out where it is safe to lift the car from when it comes to jacking up the REAR, and where I can place the jack stands?
Thanks guys
Lots of posts on this. Try the search function
Put the jack on the rubber hootus just in front of tire
996674
put the jack stands anywhere along the pinch weld that has a gap for the saddles:
996676
Reactions: 70barcuda
2014 SRT Core
The back is easy, as mentioned above use the rubber jack point in front of the rear wheels, as for the fronts they are a bit more problematic. I've used the pinch weld method, using magnetic jack pads from Zl1 automotive, this worked but I don't really like lifting the car by such a thin piece of metal but is one of the few options for use with the jack stands.
2019 Scat Pack; 2018 SXT
I bought the Lift Pad Pros set. Not installed yet. I also bought some polyurethane Corvette jack pucks. They fit into the frame rails oval opening, same location as the front Lift Pad Pros setup. For the rears, I think they should fit into the oval opening as well, just next to the factory rubber pad.
