just wanted to double check exactly what to adjust predator to i appreciate your help as i have seen alot of different recommendations, as far as the exact temps recommended temperatire settiings for the areas below- under my settings it shows the following and im curious to the recommended settings
COOLING FAN AC OFF
(in that menu it lists these)\
HIGH MPH HS FAN ON
HIGH MPH LS FAN ON
HIGH MPH MS FAN ON
LOW MPH HS FAN ON
LOW MPH LS FAN ON
LOW MPH MS FAN ON
the other menu is
COOLING FAN AC ON
(inside that menu is)
HS FAN ON
LS FAN ON
MS FAN ON
COOLING FAN AC OFF
HIGH MPH HS FAN ON
HIGH MPH LS FAN ON
HIGH MPH MS FAN ON
LOW MPH HS FAN ON
LOW MPH LS FAN ON
LOW MPH MS FAN ON
the other menu is
COOLING FAN AC ON
HS FAN ON
LS FAN ON
MS FAN ON
