1 - 14 of 14 Posts
Hi, I recently installed the JLT catch can specific for the 5.7. Its mounted to fit the oem engine cover, however I also purchased the 6.4 half covers and the catchcan is blocking the engine cover from setting.
Does anyone know if I can relocate it to another position, or the bolt size so I can purchase a longer bolt with spacers to move the catchcan out a bit?
Oh and I have the oem intake with the silencer on.
Any help would be greatly appreciated it.
Thank you
Thank you
I'm sure you can remedy that situation by just buying the 6.4L mounting bracket for that catch can, assuming it's available separately. If not, you may have to get creative...
the srt has the same bracket but I cant found it at the same location because the intake silencer is in the way.
Has anyone cut the silencer off and plug it
that's basically the same intake as the charger
I have heard of folks buying the intakes without the silencer to replace theirs with one, so that's certainly an option. I have not heard of anyone cutting the silencer off though, that would be a last resort in my book. You would have to get the resulting hole plugged up completely air tight or risk engine damage from breathing in unfiltered air (sure, it would be very minimal damage, but over time, it would add up).
You need to replace the intake tube with one without the silencer. Either by buying one from a charger or get a cold air intake. That way you can use the stud from the engine for the catch can. I'm assuming that's what you have. I know it's cheaper to get the intake tube from a charger.
Some have just cut off and covered the hole...it will work
Canada doesn't sell Mopar parts? :D
It does but a lot more expensive then on Amercian sites
The same part is $200 CAD plus taxes and shipping so almost $300
The link I posted he did his cleanly, looks better than cut off and patched, but cut close to tube, covered over and taped, etc. could look ok
Oh sorry the pics didn't show on my com, but I will try it out and post pics when done... if it turns out okay =D
If you had a Billet Technology catch can, like me, you could buy a Z-bracket to gain clearance. That is what I have on my 2009 SRT.
Discussion Starter #13
I wish I brought the BT one
I might try spacers first to see if I have enough clearance
If not then I gotta get creative
1 - 14 of 14 Posts
