Those of you that have the JFB, what part number or part name did you use? The have hundreds of exhaust products - was it a system or just a muffler?
Just a muffler...a dual-in/dual-out muffler with 2.25" pipes.Those of you that have the JFB, what part number or part name did you use? The have hundreds of exhaust products - was it a system or just a muffler?
FB4554 is the part# from Jones Exhaust website(see 'F' at bottom of page):
Performance Exhaust Systems
I ordered mine from Summit, which uses part# JEX-FB4554:
Jones Full Boar Flow Deflector Performance Mufflers FB4554 - SummitRacing.com
All this is assuming you are talking about the 2011+ exhaust. For 2010 and below, they will have 2.5" exhaust, and it is set up a little differently, so it requires a different muffler and installation procedure.
Nuke[/QUOTE
Thanks. So this muffler replaces the two mid mufflers - is it a direct fit or do you have to replace other piping?
It's a direct fit in that the muffler shop will cut the two exhaust pipes coming out of the x-pipe and weld the muffler in place for them to empty into. But then they will have to add extra piping to connect to the output pipes on the muffler so that the exhaust is routed out the back of the car in the same place as it was before being cut (and resonators being removed as a result).Thanks. So this muffler replaces the two mid mufflers - is it a direct fit or do you have to replace other piping?
The short answer to your question is "no", it is not a direct fit.Just a muffler...a dual-in/dual-out muffler with 2.25" pipes.
Nuke[/QUOTE
You are going from a true dual exhaust system with each side having it's own muffler and resonator to a pseudo-dual exhaust system where the muffler is shared between the two sides but each side has its own exhaust pipe post-muffler, exiting the rear of the car.
But it is a fairly straightforward mod for any competent exhaust shop, so in that sense, yes it is a direct fit.
Nuke
