I'm looking for a used axle out of a junkyard. Found an 09 charger with automatic but don't know what engine was in it. Diff has a tag that says 3.90 but I thought 3.92 gears were manual trans only? Any way to know what ratio is in that axle?
3.90's appear to have been an option for some of the Automatic V6 2009 chargers. To be honest I couldn't tell you if the charger/challenger axles are straight swaps, especially from a 2009 to 2014. Maybe someone else can help with that.
3.90 ratio was in 4 speed automatics with 2.7 engines mostly. The swap is only good for V6 challengers up to 2010. I think what you want is a differential, not an axle like you posted... Correct???
Yes, diff and axles from what I understand. So there was a 3.90. Wow...no that won't work for the ridiculous OD ratio on this car. Thanks guys.
The two most common swap ratios that are used for the V6 are 3.64 & 3.90.
