1 - 2 of 2 Posts
The K&N 69-2550TTK Typhoon air intake system is a free-flowing, mandrel-bent aluminum tube air induction system designed to fit some Dodge Challenger/Charger SRT Hellcat models. The restrictive factory air filter and air intake housing are replaced by the K&N Typhoon air intake which is designed to dramatically reduce air flow restriction as it smoothes and straightens air flow. This allows your engine to inhale a larger amount of air than the factory air intake. More air means more usable power and acceleration throughout the engine’s RPM range. In addition to more power, this air intake system improves engine sound with more aggressive and deeper acoustics during acceleration. The 69-2550TTK air intake comes with a chrome topped K&N high-flow air filter and a heat shield that installs into the original air box space. Air is directed through the intake tube into the engine’s throttle body for a guaranteed power gain. The intake tube has an attractive black powder-coated finish that's made to last and it accommodates the factory mass air sensor and crank case vent hose. The oversized cone shaped air filter can be used for up to 100,000 miles before servicing is needed depending on driving conditions. This air intake is relatively easy to install usually in 90 minutes or less using existing factory mounting points. The tools needed are a screwdriver, ratchet set and several wrenches.
  • Guaranteed to increase horsepower
  • Designed to improve throttle response and engine sound
  • Free-flowing aluminum tube
  • Easy to install, usually in 90 minutes or less
  • Filter lasts up to 100,000 miles before service is required
  • Replaces entire factory air intake system
  • Washable and reusable lifetime air filter
  • K&N Million Mile Limited Warrantyj
For more info or to order:
K&N Typhoon Cold Air Intake 15 Challenger/Charger SRT Hellcat
We have these in stock for immediate shipment!
How much is it "guaranteed" to raise the HP and how does the guarantee work??
1 - 2 of 2 Posts
