How do you do the key trick? I turn off my ESP but when I hit 4th gear I can fill the brake pump running.:werd:
you only want to be going 10-15 mpg IIRC, turn the key to right and ESP light should come on
If you have a trac pack you can just hold the ESP button in for a few sec. or like said turn the key to the start position above 15 MPH in both cases you should hear a chime when it activates.
I don't know, the window sticker list the track pack in the 27F package but it's not a super track pack. I tried turning the key but nothing happened so I pushed the ESP button and turned the key, still nothing. Oh well Ill try a gain tomorrow Ive got other things to do right now. Thanks guys. Y'all have a good night.
Got it !! Works great thanks for the help. Now can't wait for the track to open April 9th and see what it will do!!
i think the key trick only matters if you want to drive sideways...
i've been doing the key trick over a year and i cant tell a difference between that and a momentary press of the ESP button to kill the traction control mode. --when i want to go straight--
to go sideways...
key trick.
(base SE)
