no extenders needed i have the long tube headers and there high flo cats for last year and a half the car needed an inspection back in november i had the CEL off until then it came down to the rear senser the they came out with new ones with the same gain and said they should solve the CEL problem i put them on now i have to put some miles on to find out if its trueso these wont throw codes? any extenders needed?or do the o2 sensers mount right in the pipes.what do they claim the gain will be.
i p[ut them on my selfHello Tbone, who will you use to install them?
no i drove the it the speed limit every time just tried it with out the steel wool no luck threw codes P2098 P2271 this timeWhen you first installed them did
You let the car adjust to the
New flow and take it
Slow for the 50 to 100 miles or did you get on it right
Out of the box
To see what they could do
The solo's wont fit long tube headers.The location of the cats on long tubes are a lot further down compared to shorties,being located so far from the stock location alters the temperature and flow of the exhaust tripping all kinds of 02 sensor codes.I don't want to hijack your tread and don't want to say anything bad about kooks but have you thought about solo's new hf cats. I and a few other members have them and we have no cel trouble. I am the first tester and have almost 1000 miles on mine and the first set I tested had over 2000 miles on them with no trouble. It's just a thought I'm just trying to help.
