1 - 3 of 3 Posts
Ohio-Speed is having a Sale on KW Coilovers with FREE S/H!
PM FOR CT MEMBERS ONLY PRICING!
2011 2014 Dodge Challenger KW Suspensions V1 Inox-Line Coilover Lowering Kit 10227018
KW Variant 1: Sporty - Balanced. With KW factory pre-set dampening.
The ideal system for customers who like to choose the customer lowering of their vehicles while counting on the extensive driving tests of our experienced engineers who have preset the dampers for the ultimate balance between sporty driving, comfort and safety.
KW Coilover Kit V1 2011+ Dodge Challenger V6+V8
Front Lowering: 1.2" to 2.6"
Rear Lowering: 1.8" to 3.3"
Notes
02: Front height adjustable by threaded shock bodies. Rear height adjustable by adjustable spring perch.
28: The factory self leveling shock absorber has to be replaced with the supplied sport shock absorber
2011 2014 Dodge Challenger KW Suspensions V2 Inox-Line Coilover Lowering Kit 15227018
V2 Inox-Line Coilover Lowering Kit.
KW Variant 2: Sporty and personalized with adjustable rebound dampening.
This system is designed for the driver who requires not only determining the individual lowering of their vehicle, but having the ability to adjust the damper settings to fine tune the system to their needs.
The adjustable rebound damper allows adjustment of the pitch and roll of the vehicle adapting it to one’s own driving preferences.
KW Coilover Kit V2 2011+ Dodge Challenger V6+V8
Lowering
Notes
2008 2010 Dodge Challenger KW Suspensions V1 Inox-Line Coilover Lowering Kit 10228006
0.8"-2.0" Front Body Drop
0.9"-2.1" Rear Body Drop
Threaded Struts Adjust Front Axle Height.
Springs and Dampers Adjust Rear Axle Height.
Variation 1 Inox coilovers take the worry and guesswork out of adjusting the damper settings when you drop the ride height because they have been optimally pre-set by KW Engineers at the factory to achieve the best balance between sport handling, comfort, and safety – at any ride height.
Each individual coilover can be lowered by hand.
2008 2010 Dodge Challenger KW Suspensions V2 Inox-Line Coilover Lowering Kit 15228006
Variation 2 Inox coilovers are designed for the experienced driver who prefers to set their own ride height and damper rebound rates.
This set of 4 coilovers offer an infinite number of damper rebound settings, rather than a fixed number of choices.
Part #:15228006
Front Drop Range: 0.8"- 2.0"
Rear Drop Range: 0.9"- 2.1"
Front spring rate: 500
Rear spring rate: 685
2008 2010 Dodge Challenger KW Suspensions Clubsport Coilover Lowering Kit 35228806
Clubsport Coilover Lowering Kit.
2-Way Adjustable, with Front and Rear Top Mounts.
This is a set of front and rear integrated twin-tube coilovers with multiple settings for ride height.
2-way adjustment provides separate, manual adjustment for both compression and rebound rates to further optimize vehicle load, tire characteristics and different track conditions.
100% street legal for the enthusiast who participates in track day events but also needs to drive their vehicle to work every day.
PM FOR CT MEMBERS ONLY PRICING WITH FREE S/H!
1 - 3 of 3 Posts
