1 - 2 of 2 Posts
KW VARIANT 4 COILOVER SYSTEM 2015-2018 6.2L CHALLENGER/CHARGER SRT HELLCAT
KW Variant 4 coilovers combine leading racing technology with a clear plus in everyday practicality for top-class super sports cars, sports cars and performance sedans such as the Dodge Challenger and Charger SRT Hellcat. These allow independent adjustment of the rebound damping as well as the low-speed and high-speed compression damping. KW provides the Variant 4 with a vehicle-specific comfort setting and the adjustable dampers can be set intuitively with the integrated adjustment wheel at the damper quickly to a performance setup, if required.
The KW coilover kit Variant 4 is manufactured depending on the vehicle-specific requirements in versions for McPherson suspension struts, spring struts for double cross-link or multi-link axles as well as push-rod wheel suspensions made of aluminum or stainless steel. The KW coilover kit Variant 4 is manufactured depending on the vehicle-specific requirements in versions for McPherson suspension struts, spring struts for double cross-link or multi-link axles as well as push-rod wheel suspensions made of aluminum or stainless steel.
Features:
  • Racing technology from the 24h-winner
  • Dampers can be adjusted independently of the rebound
  • For rebound and compression damping Low- and Highspeed
  • Vehicle-specific comfort setting and the adjustable dampers
  • Rebound damping: comfortable adjustment
  • With 16 exact clicks
  • Low Speed compression: with 6 exact clicks
  • High Speed compression: with 14 exact clicks
Lowering
  • Front Lowering: 0.2" to 1.0"
  • Rear Lowering: 0.4" to 1.2"
Notes
  • 02: Front height adjustable by threaded shock bodies. Rear height adjustable by adjustable spring perch.
  • 88: Electronic dampening control has to be deactivated. Deactivation kit is included.
To Order: KW Variant 4 Coilover System 2015-2018 6.2L Challenger/Charger SRT Hellcat
Thanks
Chris
1 - 2 of 2 Posts
