1 - 3 of 3 Posts
Now that my engine has at least 1k in it I decided to try out 0-60. Best I could get was 5.9 and my tires are spinning too much in first and second gear.
Tried the Launch Control and couldn't get it to help at all. I hit the trak pack button, RPM is set to 2.5k, hit launch control, the screen (instrument cluster) makes sure your steering wheel is straight and that you are stopped, it says to press the clutch and the gas pedal all the way. Either the engine cuts at 2.5k or bogs down on me. I'm sure I can better my time if I learn to keep the tires from spinning, but I think the LC is supposed to help with that. Not sure what I'm doing wrong.
Its a 2015 RT Plus 6 speed Eagle F1s. Both tires are spinning so my LSD is working good.
1 - 3 of 3 Posts
