At first I though my seat belt might have been partially in the door and hence was frozen and wet.
Then today when I put in on and was wet and realized it always retracts normal and must be getting wet from inside the panel? Don't know where water could be getting into it unless its leaking from the pillar or roof seam? Any one else experience this. It's a 2017. Guess I need a garage.
Or, possibly a leak around the quarter window?
The retractor is bolted to the inside of the quarter panel at bottom of b-pillar area. Water works its way down by gravity, so it would have to enter from some point above where the belt / retractor is.
Then today when I put in on and was wet and realized it always retracts normal and must be getting wet from inside the panel? Don't know where water could be getting into it unless its leaking from the pillar or roof seam? Any one else experience this. Its a 2017. Guess I need a garage.
Hi beebad,
We regret to learn of this concern and understand how this could be frustrating. We would like to offer our assistance should you choose to visit a dealer. Please feel free to send us a private message with additional details.
Julie
Dodge Social Care Specialist
I'm noticing my seat belts being soaked. But only the portion behind the plastic panels. 2016 R/T. Window sealed. Window gasket/trim all in place. As much as the plastic panels appear dry along the door. Have you found out what might have been the cause on your Challenger?
Hello AAchally,
If you end up going into the dealer for an inspection, let us know. We're available via direct message and would be happy to help with the servicing process.
Jasmine
Jeep Social Care Specialist
I'm glad to find that I'm not the only one. My 2018 (no sunroof) is doing the same. We had heavy rain last week, and my seatbelt was soaked, carpet below it not wet, and no obvious source was found. I left the seatbelt extended to help it to dry... only for it to happen again next time it rained. And with it, the mildew smell.
Did I mention that it is a 2018? With no collision or body damage whatsoever.
And of course it is out of warranty - so I cannot afford hours of "searching for a leak" at the dealer.
Help?!
