Hey there. Daughter has a used 09 Challenger and radiator was bad so we put in a new one, but it was the bigger model from Summit, but fits fine. Went in easily and ran fine for a couple weeks...but
After that we started having troubles with fluid leaking out of the reservoir cap, and now she's getting a leak inside the car that pools under the gas pedal and brake pedal.
is there a pressure difference in the new radiator causing this?
Also, where is the leak occurring where the fluid is inside the car? I assume its a heater line or something under the dash area that popped or was a bad line, but all this is annoying and hard to pinpoint.
Its not a leak on the firewall in the engine bay as no wet there when I looked and felt around. Im checking for a head gasket leak today, but i doubt that since the car would be losing fluid in the engine bay and not in the cab.
Thoughts? thanks!!!
Thoughts? thanks!!!
