I have been racking my head trying to decide where and how to install my mini shift light for a couple of months and finally decided to put it on the steering colume:
That should work great, about the same place as my Raptor with remoted shift light (controller on kick panel) 7LEDs even covered in daylight you won't miss that light! :D
Sick'e bee, did you have to use the Morpar part number P5410598 to get your light to work?
I just mounted mine until I fig. out where to run the wiring harness through the fire wall.
Is that not a Raptor, since you wrote Predator but it LOOKS like a Raptor. If it is NO you need only connect the green wire to the PCM, but not sure which wire as its model specific, so if it is a Raptor they have the wiring diagram at their site, if not should be at whatever manufacturers site. Look under the hood, on drivers side of/on firewall you will see a solid grommet near/above and to center of steering gear, that is the one most use to go from inside to outside the car, drill/slit etc.
