1 - 20 of 37 Posts
Do you want to protect your wheels and tires from being stolen? The best security is locking lug nuts. These special wheel locks will help keep your wheels and tires safe even in dangerous neighborhoods or unlit parking lots. You’ll sleep better at night knowing that they will still be on your car when you wake up in the morning. Without a unique key, most thieves will be stopped in their tracks if they attempt to steal your rims and may move on to easier scores.
1011077
Thieves are not only after your rims but also after your tires. It’s not just low profile tires that are fetching a premium on the black market. If you own run-flat, SUV or off road truck tires, you may be a target as well. If your tires are stolen there’s very little chance that you’ll get them back. Once they hit the black market they can be sold online in minutes for a premium.
In fact, in many cases these crimes don’t even get reported to the police or insurance companies. Most are left scratching their heads as to how they became a victim. The reason these crimes are on the rise again is because it’s easier than ever to make a profit by selling aftermarket parts online. Without wheel locks, you may find your tires for sale online too.
1011078
The National Crime Bureau recommends protecting your tires and wheels with:
·Tire Locks
·Lug Nut Locks
·Vehicle Tracking Systems
·Park in High-Traffic Areas
A standard set of wheel locks come with 4 or 5 lug nuts and a special removal tool. These nuts will look different than your original lug nuts. They are a special shape, usually larger than normal wheel nuts, to prevent a standard socket from fitting on the nut. Instead you need to use the special key to remove the nuts from your wheels.
You will replace one lug nut on each wheel with the new locking nut. Keep your spare lug nuts in a safe place in case you purchase new wheels later down the road. Although thieves will be able to remove 4 of your 5 total lug nuts, they will not be able to take your wheel and tire without removing the last nut.
If you are feeling overly protective of your new wheels, you should install 2 locking lug nuts on each wheel directly across from each other. This will prevent your car being jacked up and dropped to snap off the lug that has the lock on it. If you want the ultimate protection, you can replace all 5 of your lug nuts on each wheel with locking lug nuts.
Remember to put your wheel lock key in a safe and secure place. While it may be tempting to keep it in your glove box, it is not advisable. If a thief breaks into your car they will have access to your special lug nut key and can remove your wheels in minutes. Preferably, you should hide it in the trunk, under your seats, or in a special compartment. Also, never leave your special key at home. In the event you get a flat tire, you or a roadside assistant will need the key to put on the spare tire. Without the key you will be stuck on the side of the road until you can find a creative way to remove the lock. It’s not easy and in some cases it can be very expensive.
Popular Brands of Wheel Locks
If you’re shopping around for wheel locks you’ll immediately notice that there are only a few brands on the market. The most popular brands include Gorilla, McGard, Muteki and DP Accessories. Each brand has a lot to offer as far as styles, colors and locking systems.
Gorilla Lug Nuts
Gorilla Automotive Products is the leading brand in the wheel lock industry. They have been in business for 35 years and there’s a reason so many people purchase Gorilla lug nuts- because they work.
With headquarters in Los Angeles, CA they have access to technology and talent that has helped them produce high performance products. Not to mention, they can put their products up to the test on some of the most dangerous streets on the West Coast.
Gorilla Guard Wheel Locks provide extra protection to those that need it most. These locking lug nuts feature a unique free-spinning sleeve to prevent thieves from by passing the security key pattern found on standard locks. According to the product website, the locks are designed with the narrowest groove possible for added security.
1011079
All Gorilla lug nuts are manufactured with case-hardened steel and chrome plated for that showroom look. Here are the pros and cons of these locks:
Pros
Attractive high shine finish. Chrome plated for enhanced durability. Features narrow groove design for a secure hold. Tough steel construction. Available in several thread sizes. Resistant to weather changes.
Cons
Expensive. It may be a bit complex to slide in and lock the key. May break during installation.
McGard Lug Nuts
McGard has a long history in the wheel lock business. They opened their doors in 1959 and in 1960 the founder, Lewis D. McCauley, designed and patented a security nut to prevent the theft of car tires and wheels. Today, they are an international company that produces anti-theft devices for auto, marine and even municipal applications, as well as locking lug nuts for Mopar. While they offer a wide range of products, their most popular lug nuts are available in shank, cone seat and bolt style versions.
1011080
McGuard Wheel Locks are unique because they have a protected, internal locking pattern to prevent tampering. With exterior lock patterns, persistent thieves can find a way to adapt a standard socket to the nut. With McGard you don’t have to worry about this. Here are the pros and cons of these locks:
Pros
Cost-effective. Hardened for durability. Features a corrosion-resistant chrome plating. Minimal chances of key duplication. Features different computer-generated patterns on each key.
Cons
May be too small for most trucks and SUVs. The inner threads may get rusty and jam. No spare locking nut included.
DP Accessories Wheel Locks
DP-Accessories is a premium brand of wheel accessories available only through Driven Products. Their wheel accessories have been dominating the industry since 2008, with options including lug nuts, lug bolts, wheel locks, installation tools, hub centric rings, wheel spacers, and more.
They make hundreds of different shapes, styles and colors to choose from. Every wheel fastener is made from cold forged steel with precision machined threads and a beautiful yet tough coating. Several different key patterns are used.
1011081
Pros
Temperature-, rust-, and corrosion-resistant. Tough construction. Looks good on both dark and light alloys. Each package has a different key and lock combination. Resistant to intrusion by lock removal tools.
Cons
Not a perfect fit for every vehicle. Not as secure as the pricier lug nuts. It only comes with one key.
Muteki Lug Nuts
Muteki is a Japanese parts brand with a long-standing reputation of producing high-quality parts. One of their most popular lug nuts is the SR48. This is an open-ended lug nut with a knurled end for better grip and a cool look. These lugs are designed to give you race performance with car show looks. A perfect combination.
All Muteki lugs are manufactured using cold forged chrome vanadium metal, so they can handle almost anything you throw at them on the street or strip. They are designed with an oversized 60 degree cone seat that gives better contact on your wheels. One of the unique advantages of Muteki lug nuts is that they come in a wide range of colors. They are currently available in titanium, burned blue, pink, chrome neon, red, blue, and black.
1011082
How to Remove Locking Lug Nuts
The only way to remove lug nut locks from your wheels is with the special key that comes with the set. While you may find videos on YouTube showing you how to buy pass old wheel locks, these methods no longer work. That’s good news if you are looking to buy a new set of locking lug nuts- not such good news if you lost your key.
The majority of ways shown online to remove lock nuts is to use a large socket and brute force to break them free. You’ll notice that most brands like McGard and the Gorilla Guard lug nuts have an internal nut pattern that prevents any potential security breaches.
Where to Buy a Replacement Lug Nut Key
If you lose your special key, you’ll need to order a new one from the manufacturer. In order to get the right key, you’ll need the special key number that came with your wheel lock set. Without this code, the manufacturer with have a very difficult time sending you a new key.
This key number tells them this size of your lug nuts and the pattern on the end. As would be expected, patterns and configurations have changed over time to prevent thieves from getting past these wheel locks.
As a last resort, if you cannot find the registration card that came with your locking lug nuts, you can buy a master key set from Steelman for about $70 at Walmart or other stores.
1011085
As previously mentioned, it is important to keep your wheel lock key in a safe and secure place. Eventually, you will need to use it again. Whether you get a flat, buy new tires or wheels- you need the key to remove the lug nuts. Even though you can easily order a new one from the manufacturer, it can takes days if not weeks to get one delivered to your door. Not a fun prospect if your car is stuck on the side of the road with a flat tire.
2014 Challenger SRT 8
I have extra insurance, Locks are UGLY on these...........SO took them off !!!
Good POST !!
FYI, spare tires get stolen more often.................
Reactions: Dennis H
I havent used any locking lug nuts for probably more than 20 years. Never had a problem,....dont feel the need for them or their looks.
Now having someone trying to break in is another story though feeble attempts. Ive caught two people on camera trying to see if the car is unlocked. Sent one of the videos to cops as that person actually broke into a neighbors car and they caught him from my video clip.
They want my Wheels, fine. With insurance I can buy some other wheels and new tires.
Congratulations. I prefer to spend my time learning useful skills. Why is everyone on the internet an a-hole?
No call for that, far from a A HOLE !!
Those locks looked like SHIT on my SRT 8, took them off.
Theft can never, ever be stopped.
Reactions: Dennis H
Lol, so leave the car unlocked and the fob inside...
Everyone assumes the thieves are highly skilled experts, not some dirtbag who will see they can't remove the lugs and move on to the next car. My locks look like lug nuts, you got the wrong ones
1007605
I got gorilla ones in black , goes well with my black car. Good customer service too. I’d suggest having locks in conjunction with a shock sensor alarm and maybe a dual channel dash cam. If they force a bigger socket on the lock alarm will go off and likely the motion and impact with send an alert to your phone with the dash cam. Nothing is fail proof but it’s a deterrent and inconvenience that would likely have them target an easier less protected car.
Thieves have been stealing wheels with locks on them for a long time. Plus, you take your car in for an oil change and tire rotation and discover you can't find the key. JMHO don't use them, however, if you want locks on your wheels by all means use them.
I don't park my car where it's at risk. Ever.
My car is never left unattended unless at a show for me to take a lap, nobody has the stones big enough to take anything as they can’t watch the crowd looking for the owner to come back. I caught someone in the 80’s trying to get in my new Mustang GT, I’m not sure about now but after he met my Louisville slugger he had trouble walking for a long time. I’d like to think he chose a new path in life after that beat down. Back in the day it was 2 hours a day in the gym 7 mornings a week. He sure picked the WRONG house.
Reactions: Sully’s Hemi
I use the Mopar accessory wheel locks on both my Challenger and my Chrysler 300C, they are made by McGard and work quite nicely, and still look nice.
My rigs are also garaged or otherwise secured so theft is not an issue. Burglars get shot where I live in AZ.
2020 Dodge Challenger Scat Pack Wide body A8 in Go Mango
Ordered my new ScatPack without locking lugs from the factory. They put them on anyway, so, I’ll leave them on. Curious, where does everyone store the socket to remove the locking lug. I see so many leave it in the glove box or console.
1007849
1 - 20 of 37 Posts
