Low idle miss
2346 3
Ive changed plugs and coils in my 2011 rt. Still have a miss. Acts as if it has trouble taking fuel. Could it be an o2 sensor, or injector? Put it on a computer said 1 and 3 cylinder misfire.
1 - 4 of 4 Posts
2018 Challenger R/T 392 6 speed manual
Probably not an O2 sensor but it could be injectors. If the misfire codes are always on those two cylinders, then you could just swap the injectors to see if the misfire codes follow the injectors or not. If it’s the injectors, there are places that will clean them properly and do flow bench testing before/after.
how many miles on the engine?
my first thought is it’s the lifter/cam problem that afflicts these Hemi engines. I hope that isn’t the culprit here, but not enough info to really diagnose.
2 different cylinder misfires at once could be the result of low fuel pressure. I wouldn’t think two injectors would go at the same time.
Not going to be an O2 sensor.
More info needed to continue troubleshooting...
Cylinders 1 and 3 are next to one another. The misfires could arise from a head gasket failure between the cylinders.
Or both cylinders have suffered some valve/valve train issue.
Or it could be an injector problem.
Or low fuel pressure and 1 and 3 misfire first.
As much as I dislike messing with a car's fuel system in this case I think you are at least going to have to swap injectors moving the injectors from 1 and 3 to other cylinders and moving the injectors from those other cylinders to 1 and 3.
You don't have to do both at the same time. Try just swapping injectors between 1 and another cylinder. If the miss follows the injector then you can also proceed to cylinder 3. If the miss doesn't follow the #1 injector that is not a guarantee this will be the case for #3 injector. So you would or should try swapping #3 injector with an injector from an apparently healthy cylinder.
If the injector swapping doesn't help then that suggests the problem is internal to the engine. For a suspected head gasket failure or any issues with the valves a compression test is called for. And after maybe a leak down test.
1 - 4 of 4 Posts
