I have a 09 challenger rt auto. Im going to be running 22s with 265-40s tires. Right now i have the srt bilsteins and srt springs which gave me about an in drop. But im looking for another inch. Now the say the rt lowing springs lower it 1.8" which would be good. But is that on stock rt shocks. But i want to keep my srt shocks. So would i buy srt lowering springs? Not sure how i should go about this? Any info would be great. Thanks
You're gonna have problems with the 40s on the front. Even with 265/35/22s there is barely any clearance on the front. Where the upper control arm attaches to the spindle the tire only has about 1/16" clearance between the tire and the bolt with 265/35.
Reactions: rajunz
Dam but the 40s will fit on the back? They came off of a 300c which i believe runs the same tires. Ill have to bolt a rim up and see i guess. If they dont can i run the 35s in front and 40s in back? Should be able too right.
Here is the clearance issue in question. This is my car with 265/35/22 and there is very little clearance.
