1 - 15 of 15 Posts
Great thread!
What kind of car do you have ? A bunch of us will have photos of our cars or customers cars lowered. Check out the pictures listed below, these care our lowered with our Speedlogix springs.
Land vehicle Vehicle Car Motor vehicle Automotive design
Land vehicle Vehicle Car Blue Full-size car
Land vehicle Vehicle Car Automotive design Rim
Land vehicle Vehicle Car Green Coupé
- Alexis
I just got a 2020 Challenger R/T Scat Pack .... 3 miles on it when I got it so I'm going a little bonkers trying to put some break in miles on it.
I think the first thing I want to do is some weight reduction (wheels and maybe carbon trunk / hood), slightly lower, and stiffen up the suspension
SO in that light I made the thread hoping to get some opinions on the lowering kits and their effect, the pictures you posted look very nice.
Eibach Pro
Before
Land vehicle Vehicle Car Motor vehicle Wheel
After
1006509
Reactions: T240guy
1 1/2" Ride didn't change as far as stiffness, but less roll in fast corners. Mind this is an SXT Plus, so less stiff suspension than your Scat to begin with
@A Guy was the after pic taken immediately after installation, or is that after 1000 miles of settling? I just remember on my 240sx that eibachs always took time to settle?
@Speedlogix-Sales what is the advertised drop with SL springs? The gray challenger is sitting
@JasonT/A_345 how is your clearance on the h&r springs.
I want to get mine lower, but not sportline low. I have the adjustable system on mine, but want it a little better grounded. Springs, sway bars, and such.
Sent from my Pixel 2 using Tapatalk
2017 Dodge Challenger T/A
Clearance is good. No rubbing, no spacers with 315's on rear. I do scrub my zl1 front splitter a little easier now but thats what its for.
The picture is later, but measurements show no "settle", exact same height the day after they were installed to today. I have always questioned how steel springs with a rating and specified height would "settle". The stock springs don't settle. If anything, I'd think any "settling" is from the way they are installed, isolator position, etc. If properly installed, springs should not "settle"
Every spring made in-house is pre-set several times in a spring compressor, that is, compressed so all the coils are touching. This gives the spring a permanent set and ensures it will not settle during its service life. In production, a spring is actually made to a longer free, or uncompressed, length than required because the spring gets shorter during the setting process, thus bringing it down to specifications. Pre-setting is time consuming, though, so many spring manufacturers will skip it altogether. Once Eibach pre-sets a lot of springs (about 100), several are randomly selected to go through quality control, then the bulk go to powdercoating and labeling.
PS, Jason's T/A would likely be more indicative of the "before" height of your Scat, and the drop after with it's stock ride height and V8
Reactions: T240guy
Thank you for the response. It must have been the springs seating into new poly's and struts on all 5 240sx's that I installed eibach on. 3 were sportlines and 2 were pro kit. All of these installs were 15+ years ago as well. I will look into the H&R springs, but may look at more prokit pics as well. I want lower, but without daily driving problems. Roads aren't the greatest in Arkansas.
Ride Height: Moderate
Lowering Note: 1.25"-1.7" front & 1.25"-1.5" rear
- Alexis
1 - 15 of 15 Posts
