1 - 4 of 4 Posts
I used one on my intrepid after I let a quick lube place change the oil and they stripped the drain plug. Only time in my life I let someone else change my oil. I didn't want to chance damaging the threads more and didn't want to mess with drilling and tapping so I used a liquivac for years to extract the oil. I finally got around to fixing it using a time-sert oil pan repair kit. Worked perfectly. I've also used it to extract trans fluid.
I installed a fumoto valve on my challenger to make oil changes easier.
Reactions: skynyed
Great thread, didn't see that in my search. Lots of useful info from several members. Thank you all.
Busy week so I didn't have time to do much more researching.
Ended up using ramps and crawling underneath yesterday.
Easy enough but somewhere along the line I got distracted and did not put the new o ring with the K&N filter on correctly. :yikes:
950 miles and I got oil splattered in the engine bay.:twak:
1 - 4 of 4 Posts
