1 - 10 of 10 Posts
Ohio-Speed is having their i wish it was spring sale on the Megan Coilovers.
2008 2010 Dodge Challenger SRT-8 6.1L Megan Street Series Coilovers MR-CDK-DC06
2011 2013 Dodge Challenger SXT/SE/RT/SRT-8 Megan Street Series Coilovers MR-CDK-DC11
Megan Racing Coil-Over Dampers are the ultimate upgrade to your track or street car.
Featuring 32 Levels of damper force adjustment, full-height adjustment, these damper kits are then perfectly matched with front and rear Pillow Ball upper mounts for camber correction in most applications.
The adjustment of the damper is as simple as can be with a built-in knob at the top of the damper mount for easy access.
Simple adjustments can be made to tune to your style of driving and comfort level desired.
Single-Adjustable dampers make suspension adjustments easy to tune whether you’re a professional mechanic or an automotive enthusiast with amateur mechanical skills.
The height adjustment is made easy with CNC-Machined locking perches for accuracy and smooth adjustment.
You can raise your car up to factory height for OEM appearance with performance handling or you can drop your car all the way down for a formal racetrack and an aggressive stance lowering your center of gravity to gain full potential of your car’s handling capabilities.
On most applications, the Megan Racing Damper Kits come with fully adjustable Pillow-Ball upper mounts to easily tune and adjust your camber.
Adjustable camber gives you an edge on most suspension setups, as you can easily tune your car for any ride height which improves handling, predictability and furthermore tire wear, which is a great benefit both on the racetrack and on the street.
The quality and durability of the Megan Racing Damper kits are unmatched.
Made of extremely durable Steel and featuring springs that are constructed of SAE-9254 Cold-Wound Steel which are then tested over 500,000 times by compression inspection.
With deformation less than 5% and high strength sophisticated surface coating, we stand by our product with our strong warranty.
Features:
Spring Rates: 10kg Front and 8kg Rear
32 Levels of Adjustable Damper
Pillow Ball Upper Mounts.
Rubber Dust Covers.
Adjustable Ride Height
Aggressive Spring Rates
Single-Cylinder Design
Aluminum Brackets
All coilover damper kits come with 1 year manufacture-defect warranty.
All Hardware is Included
32 Levels of Adjustment:
1-8: Suggested for track use.
9-16: Suggested for mountain/aggressive use.
17-32: Suggested for common street use.
PM for our low price with free s/h!
How do these compare to BC Coilovers? They look to be very similar on paper.
They are a surprisingly good product for a small company that not many have heard of, I've been riding on them for more than a year.
Yes they are well made, i have had mine on the car for 2 years now with no issues.
I had the lowering springs at one time and i'm glad i made the switch!
1 - 10 of 10 Posts
