1 - 1 of 1 Posts
MGP Caliper Covers Dodge Challenger - $249.00
Set of 4 caliper covers, engraved front and rear. Custom Caliper Covers by MGP. Upgrade the appearance of your calipers, reduce their operating temperature, and reduce the amount of brake dust on your wheels with these caliper covers. These quality, aerospace aluminum covers are the smart alternative to painting your calipers, and they can be customized with your choice of color, engraving and even bolt color. Everything is included for an easy installation.
Features:
  • Makes ordinary brake calipers look great
  • Protects the wheels from brake dust
  • Reduces caliper operating temperature
  • Less time and effort than painting with better results
  • Made from 6061-T6 aerospace aluminum
  • Hydraulically formed to fit each customized with your choice of color, engraving and bolt color
  • Comes with everything required for an easy installation
  • Backed by a 3-year warranty against manufacturer's defects
  • Proudly made in the USA
Today's original equipment and aftermarket large diameter, thin spoke wheels look great, but they expose a lot of the mechanical parts behind the wheels that often don't look so great, particularly the brake calipers. You can paint your calipers, but it takes a lot of time and effort to do the job yourself, or a lot of money to pay someone to paint them for you.
Plus there are considerations with painting beyond the initial paint job. The paint will often peel, even if the surfaces are meticulously cleaned, and even the best paint job probably won't stay looking good for more than a year. And no paint job will be able to do anything about the shape of the calipers, which often isn't that appealing.
The answer to your brake caliper appearance dilemma is MGP Caliper Covers. Caliper covers will make those rusty, unappealing calipers look exceptional, and so much more. MGP Caliper Covers are laser cut from rugged 6061-T6 aerospace aluminum, hydraulically formed to fit each specific caliper, and powder coated for a durable appearance that will last. These caliper covers will make any brake caliper look better, now and for years to come.
MGP Caliper Covers can be customized with your choice of logo applied using proprietary CNC high speed engraving techniques. They're also available with your choice of finish, so you can have color that matches or contrasts with your wheels or paint.
And speaking of wheels, with MGP Caliper Covers your wheels will stay much cleaner, because they help reduce brake dust. You'll also get reduced caliper temperatures with MGP Caliper Covers. When checked with an infrared thermometer gun, it was found that caliper cover equipped brake calipers were 30º-50ºF cooler than brake calipers without caliper covers.
MGP Caliper Covers act as a heat sink, drawing heat out of the brake calipers, prolonging the life of brake system components and reducing the potential for brake fade.
Everything required for an easy installation is included with your MGP Caliper Covers, including detailed instructions. Clips are used to hold the caliper covers to the calipers, and the bridges that the clips attach to are TIG welded to the covers for strength.
MGP Caliper Covers will not interfere at all with brake system operation and they're easy to remove and install when brake service is required.
MGP warrants these caliper covers against any manufacturer's defects for a period of 3 years from date of purchase. MGP Caliper Covers are proudly made in the USA
979316
979317
979318
979319
We'll pay your shipping to the Lower 48 states! Half price shipping to Canada.
1 - 1 of 1 Posts
