1 - 3 of 3 Posts
Is anyone running the M/T ET Street II Drag Radials 295/45/17 on the HHP bogarts as I just ordered the bogarts from Josh and was wondering how they fit? Please advise. I'm not really interested in a 275 if a 295 will fit, and it's only a 1/2" difference in width so I would think it should but if you know for sure please let me know.
Thanks a lot!!!!
Thanks a lot!!!!
Should be fine. I just bought a used set. They weigh 33 lbs each new and about 28 lbs when you burn off all the rubber. I'm going to mount them on 17x10.5" Bogarts. The tread is 10.5" wide so probably would look better on a 10" wide rim
I run those tires on 17 x 9.5 CCW Classics, and the car's lowered from SRT height. No problems.
1 - 3 of 3 Posts
