G'day,
Apologies in advance for the long post, but I'm looking for some advice as to how to proceed with different mechanics telling me different things. I've got another post on here that a received some brilliant technical info on the root cause of the problem, I'm now looking for any advice as to dealing with Midas, specifically in where I stand (legally I guess?) in terms of getting them to fix this mess. If anyone has a similar experience, I'd love to hear about it
Summarized Background:
Does anyone know where I stand on getting Midas to pay for Dodge to do the replacement oil pump (and PCM if necessary)? I asked Dodge to put this in writing, but they've sent me an email basically saying the pump is causing the solenoid to stick. I have a strong suspicion that all Midas will agree to do is replace the pump under warranty with the exact same one, which is no good to me. I'm sure their argument will be that I didn't ask for a Mopar pump, but my thoughts on the matter are that I paid them to fix the cause of my CEL, if the part they use doesn't do that, they haven't "fixed" my car.
Any thoughts appreciated. Apologies for the rant
- I bought a 2012 SXT Plus in Sept
- In about Nov, I got a CEL with code P06DD (oil pressure sensor stuck off)
- Took it to the local Midas (this is my first non-shitbox car and back home in NZ, its pretty rare to use dealers for repairs rather than independent or chain mechanics, so I didn't know any better)
- They replaced the oil pressure sensor and oil filter, CEL goes away
- 2 weeks later it comes back, I take it back, they tell me the new sensor must be faulty and replace it under warranty
- CEL comes back on within a few weeks again, by this time I've moved away (hence choosing chain of mechanics). The new local Midas tells me that the sensor is fine, so it must be the "oil filter housing and cooling assembly" which I get replaced (along with a new oil filter)
- Sure enough, its back a few weeks later, so I take it back again. This time I'm told that the next step is to replace the oil pump, although they can't guarantee that will fix it, but "it's what everything is pointing towards". Things are getting pretty pricy at this point, so I decide to hold off on fixing it
- After a month or so, when I've saved enough of my pennies, I go back and give them the go-ahead to replace the oil pump. At this stage, I've found some forum posts (on here and others) about people having this CEL code when a mechanic uses a non-Mopar oil filter. I ask them to check to make sure it's Mopar, even giving them all the info I'd found about it. They told me that it's definitely a Mopar filter in there
- The oil pump is replaced and when I go to pick up the car, the CEL is back on before I've got out of their carpark. Go back inside and their (so-called) head mechanic comes out and basically says "I dunno, just ignore the light, its not gonna damage your car".
- Obviously I don't accept that and finally take it to the local Dodge dealership. They tell me it has the wrong oil filter in it to start with, including having photos of a non-Mopar filter they took out of it, that was the wrong size and was squashed into the housing to make it fit. They eventually diagnose an incorrect voltage in the oil pressure sensor, which is causing the solenoid to stick. They say the PCM needs replaced and the part will be on back-order
- The PCM arrived last week and was fitted on Friday. The car was dropped off by Dodge and about 2 hrs later, I started in from inside the house with the remote-start function. 2 mins later, I go outside and it's dead. Turn it on with the button in the car and the CEL is back. I rang Dodge on Saturday and it was back with them on Monday.
- Dodge has now called me to say the the aftermarket oil pump Midas installed has stuck the solenoid again, causing the CEL to come on. They're willing to replace it with the correct part, but based on the cost have given me a chance to ring Midas first. I've just got off the phone with Midas and am waiting on a call from their head mechanic. Dodge are also saying that there's the chance that this f*&king oil pump may have now buggered the new PCM too.
- All up, I've dropped about 4k into Midas (including labour) on parts that were wrong or unnecessary due to bad diagnoses. On top of that is the 2k with Dodge for a a PCM that now may be ruined due to this pump and need to be replaced again.
