1 - 20 of 25 Posts
2013 Dodge Challenger SRT8 392 6Speed
Installed the Mopar lowering springs on my 2013 SRT8 challenger m6.
the front is slammed but the rear is super high 馃槀
1004433
1004434
I wonder if you might have Nivomat self leveling shocks in the rear? Part # on shock in this video
Maybe Slidd or Hal H might know if 2013 SRT8 came with nivomats?
Discussion Starter · #4 ·
Reactions: frogman
Discussion Starter · #5 ·
Pretty sure I saw the yellow Bilsteins.
Kinda digging the retro look even though I didn鈥檛 ask for it.
Discussion Starter · #8 ·
Hehe. My bad. I got charger springs for the rear 馃槃
Thats where they were back in the day I think...
I even transferred the dodge badge from the rear to the hood. 鈽
The Bacon Hauler (鈥12 Cop Charger)
So you have Mopar Stage 1 springs on the front, and the rear springs are OE like what comes stock on a SXT, R/T, or Pursuit Charger? What happened to the rears from the Stage 1 set?
Installing the matching Stage 1s is always best, but absent that going back to the original SRT rears would be a better match for the Stage 1 springs in front versus what you have now.
If worst comes to worst, even cutting a coil off the OE Charger springs would work to even out the ride height, though that would leave a mismatch in spring rates with what you have on the front.
Discussion Starter · #10 ·
No I have matching Mopar stage 1 sets. But they belong to charger.
My OE springs were cut, and TBH the ride quality was crap. Lots of micro vibrations and body roll from the resultant soft or mismatched spring rates. After installing the new ones, I could feel the difference from the first drive. It's like riding on a cloud now with no micro vibrations.
Stage 1s shouldn鈥檛 be that high in the rear, even if they were for a Charger. Something else must be affecting the ride height back there.
Are you certain the installation was done correctly?
Discussion Starter · #12 ·
am guessing so? No vibrations or other signs to suggest otherwise :/
And the rear springs are painted light blue like the front ones, correct?
Discussion Starter · #14 ·
Yes yes :) Bright blue indeed.
Actually I just confirmed the part number P5155436, and it says it belongs to Challenger.
I was not aware the Stage 1 springs had different versions based the different LX models. I was thinking they only came in one version, and that version fit all the LX models, Charger, Challenger, 300, etc.
Either way, the rear ride height of yours cannot be right. My first suspect would be that it has the self-leveling shocks back there, but you said they were yellow, so that rules out the Nivomats. Plus, it鈥檚 an SRT, and those didn鈥檛 come with Nivomats unless it was a manual transmission AFAIK.
Your car does have the automatic transmission, right?
Discussion Starter · #16 ·
They actually do have 2 versions. P4510854 works with all others except SRT8 (with active dampening). P5155436 claims to work with SRT8.
Its Manual 6 speed.
Its Manual 6 speed.
Interesting, I wonder what the difference is...
If yours has the M6 trans, it should have come with the Nivomats in the rear. The fronts would be the yellow Bilstein shocks, but the rears would not be.
Can you confirm the rear shocks鈥 color, are they yellow or OTY (other than yellow)?
Discussion Starter · #18 ·
Pretty sure I remember yellow in the rear too during install. Will check again later to be sure.
Am gonna take a wild guess and say the shock expanded during install and need time to settle? 馃し鈥嶁檪锔 :ROFLMAO:
If you have black shocks in the rear (and body of them is pretty fat for a Nivomat) the picture below top one is the rear Nivotmat vs the standard Sach that the A5 (in your years) would use.
With a Nivomat, you could literally remove the rear spring and the Nivomat will maintain the ride height on its own.
Auto part Suspension part Shock absorber Suspension
Discussion Starter · #20 ·
No black Nivomat shocks here. Only yellow.
1004484
video link for reference 馃榿
1 - 20 of 25 Posts
