1 - 4 of 4 Posts
2018 Challenger Scat Pack Blacktop Package 6MT
The rarest fact nobody seems to know accurately, is what the Pressure Plate Torque Specifications are for the 2015-2020 6.4 Scat Pack with the 6Spd Tremec TR6060.
What is the torque spec?? I've spent hours looking online and only found the torque spec for the flywheel.
I am using Mopars OE Stock Factory Clutch Setup.
I'm already torqued to 30Ft-Lbs and the pressure plate fingers barely have any curve to them anymore.. So I don't think it can be 55Ft-Lbs, Can it?
Ooops, I answered for the 5.7 Liter in the other post as it wasn't clear you didn't want the same info as the OP
Yes William, they are both 55 ft-lbs. Both the flywheel bolts and the pressure plate bolts are 10 mm bolts, just different thread pitch (flywheel, fine thread / pressure plate, coarse thread).
Torqued it down to 50 Ft-Lbs, Using a Legitimate E-Torx anything above felt like the head of the bolt wanted to shear. Already 30miles on the car and everything is working as it should. Cant believe everything you read on the internet now can you?
1 - 4 of 4 Posts
