I tried this question over at Challengerforumz with no answers so I'll try here.
I found this picture of the P5155284AB on a 2016 Challenger. Considering the boot hole is around 3/4" on the later models, I don't know how they got the boot to expand over a 1 1/2" shifter base. Is there anyone that's been successful getting it to slide over this base? I know the o-ring will have to be cut.
The o-ring will most likely have to be cut. I had to cut mine to install my Barton shifter, and even then it was a difficult challenge to get it to fit. I wound up wit an aftermarket shift boot at the end of it all.
2021 Challenger R/T Hellraisin M6
According to some questions on Amazon, the boot will fit snug and you'll need to zip tie the opening once you remove the o ring.
Reactions: omgwtfdood
Discussion Starter · #5 ·
Thanks for the responses. I see in the video that the boot really has to be cut/enlarged. That's the commitment I was hoping to avoid, but a new boot is inexpensive enough if I want to reverse it.
Discussion Starter · #6 ·
Just finished the job and in fact the boot does not have to be cut. I just wet the leather at the hole and it slid over the shifter base. Still was tight but it can be reversed without buying a new boot. I had the short adapter prior to this and the mopar is slightly shorter and the shift points feel better for some reason, possibly because of the robust construction.
