1 - 2 of 2 Posts
MOROSO AIR/OIL SEPARATOR 2015-2017 392 CHALLENGER SHAKER
Air/Oil Separator Kit - Small Body for 2015-2017 Challenger 392 Shaker
  • From the factory, a vehicle’s PCV system vents excess crankcase vapors, residual oil and moisture back into the intake manifold which compromises performance and durability.
  • The MOROSO Air/Oil Separator plumbs inline of the PCV system and captures the excess crankcase vapors, residual oil and moisture
  • Removing this oil mist before it reenters the engine; reduces detonation, deposits on the intake track including the valves themselves. During the combustion process the presence of oil mist or vapors can affect the octane rating of fuel, because of contamination.
  • Increases engine performance from cleaner intake air
  • Air-Oil Separators have billet aluminum bodies with internal baffling and mesh media
  • Includes heavy duty brass inlet and outlet fittings, Fuel/Emission/PCV Vapor hose for plumbing the Air-Oil Separator inline, stainless steel mounting bracket and billet aluminum mounting clamp for the body of the separator
  • The two piece body of the Air-Oil Separator unscrews for cleaning and draining
  • Billet Aluminum body is available either with raw or black anodized finish
  • Please note that this Air/Oil Seperator will also fit on a 5.7L Shaker if you remove the factory Silencer tube. This Mopar tube is the easiest option --> Mopar Non-Silencer Intake Tube
MOROSO AIR/OIL SEPARATOR W/ DRAIN 2015-2017 392 CHALLENGER SHAKER
Air/Oil Separator Kit - Large Body for 2015-2017 Challenger 392 Shaker
  1. From the factory, a vehicle’s PCV system vents excess crankcase vapors, residual oil and moisture back into the intake manifold which compromises performance and durability.
  2. Polished body can be chromed, painted or powdered coated for a custom look.
  3. Features a bottom drain with elbow that makes draining the collected oil virtually mess-free.
  4. Includes heavy duty brass inlet and outlet fittings, Fuel/Emission/PCV Vapor hose for plumbing the Air-Oil Separator inline, stainless steel mounting bracket and billet aluminum mounting clamp for the body of the separator.
  5. Air-Oil Separators have billet aluminum bodies with internal baffling and mesh media.
  6. Increases engine performance from cleaner intake air.
  7. Removing this oil mist before it reenters the engine; reduces detonation, helps the deposits on the intake track including the valves themselves.
  8. During the combustion process the presence of oil mist or vapors can affect the octane rating of fuel, because of contamination.
  9. The MOROSO Air/Oil Separator plumbs inline of the PCV system and captures the excess crankcase vapors, residual oil and moisture.
  10. Please note that this Air/Oil Separator will also fit on a 5.7L Shaker if you remove the factory Silencer tube. This Mopar tube is the easiest option --> Mopar Non-Silencer Intake Tube
To Order
Without Drain: Moroso Air/Oil Separator 2015-2017 392 Challenger Shaker
With Drain: Moroso Air/Oil Separator w/ Drain 2015-2017 392 Challenger Shaker
Thanks
Chris
1 - 2 of 2 Posts
