1 - 4 of 4 Posts
is anybody experienced oil leaking from the cap of the moroso PS tank.
i installed mine tonight and refilled it with what i had in the old one, level was about 1/2-1'' over the tray plate inside the tank. there a lot of oil coming out by the vent of the cap, i removed a little of oil, level was flush the tray plate, still leaking and power steering pump start yelling.
anybody can help me with that ?
thanks
Well I have the PS tank and the coolant tank. My PS tank is fine, but I have the same problem with the coolant tank. I ended up putting the factory one back in. I don't know if mine is from the cap or little holes in their welds. They do look good installed though.
You may have too much fluid. but to answer your question, yes I have it and a little does blow out the pressure relief hole in the cap.
1 - 4 of 4 Posts
