‘10 B5 R/T Classic
Hello all,
Id like to make an introduction to the site as im a new member.
I have a 2010 Challenger R/T with a NAG1trans. I had multiple codes pop up such as ;
U0100
U110B
U0141
Does this sound like a PCM/TCM issue? Wiring? Just looking for some insight if anyone’s dealt with these codes before
2010 R/T Classic 6M
Hello all,
U0100
U110B
U0141
Sound like you bought a piece of junk
2021 JEEP Wrangler Unlimited Willys 4X4
I’d start by checking out all ground wire connections. If those appear fine, I’d start next investigating main computer connections....there could be one or more pins not seated correctly in the connector.
One other thing to possibly check would be the battery. A marginally bad battery, low on voltage, can sometimes throw some error codes that are not legitimate.
2010 R/T Classic 6M
Yea car runs and drives great, I think he started playing around with the connectors and they just went away after that so was probably a bad contact. Lol just noticed my first response was deleted, my brother is the OP btw
Yeah, thanks for letting us know :rolleyes: I was thinking poor guy has issues and here JD40 has a helpful reply, lol. Could have helped him pick a user name too...JK! (Kinda)
Reactions: 732Mopar and JD40
Only an Admin can change it, and it can take a while to get their attention, unless Bernie (Rambit) sees it. Post in Community Help forum
And ask if your name can be changed to (your new choice). This can only be done one so...choose wisely
I, too, thought it was odd that you busted his balls right out of the box, but I did have a small inclination that maybe you knew him!!!!!
