is it typical for a mustang dyno to show lower hp numbers? and what do you think a stock 6.1 should come in at ?
if you do an upgrade to your car and have it retested on the same dyno would the hp rating's be the same on a different dyno?
There anywhere from 5 to 9% lower than DYNOJET. If you can always use the SAME DYNO after mods.
so if i had a 30 hp increase on a mustang ,would it also be 30 hp on a dynojet?
I think if you want to know what it would do on a dynojet, you need to put it on a dynojet. I'm also of the opinion that that wouldn't matter.
I doubt the numbers would be the exact same on 2 different mustang dynos. I hear dynojets bloat hp/torque numbers. As stated above, just use the same dyno before and after. Numbers are subjective anyway, the real proof is at the track.
Jack
