So many of the forums here and elsewhere had posts complaining of HAWK HPS pads squealing. The funny part is I have a C5 setup with HPS pads on my 69 Camaro with no issues... Not so on my SRT8. So after about $900 in parts no more NVH.
The final verdict is I removed the HPS pads, went to a Semi metallic OE type pad and a new factory rotors. I'm sad to see the better pad go, but can't live with the constant howl no matter how slow I roll to a stop or ease on the binders for a daily driver. So.. there's a set of HAWK pads up for crucifiction for cheap if anyone is auto crossing here soon... Did you hear that? ahhhh, silence...
That's really interesting because I've had the HPS pad for over 18 months and have not had a problem. Did you properly bed them after the install?
Same here. Over 3K miles on the Hawks and not a peep. The only thing is I don't get to clean the wheels as often as I'd like. :bigthumb:
Yeah, followed Hawks bed in procedure to the letter. I have the same pads on my protouring 69 Camaro with a C5 brake setup with no issues and that's why this was such a fight. This isn't the first time I've run this compound and that just added to the bizarre factor. I even spoke with the guys at Hawk, and they said sometimes there are cases where pads just squeal...
@RpaulG87 - I spoke with the guys at HAWK (Justin) - they were great and they offered up a set but I had already bought another less aggressive set and bolted the brakes back together. At that point I just needed to get it back on the road.
@the dodgeboys - The Part numbers for the HPS pads are HB194N.570 and HB563.656. Summit Racing numbers are HWK-HB194N-570 and HWK-HB563N-656
They will run you about $240 with shipping.
My advice is clean your rotors with a light cut your rotors or get another set before you you do.
Nick
