21 - 40 of 59 Posts
Discussion Starter #21
Heres the fuel line and couple more pics. One shows injectors are straight and will not be any issues. Lubricate the o rings before you install the injectors.
Discussion Starter #22
Heres the rest of modifications to make the intake work. Plastic evap/fuel lines are easiest to do with a heat gun. Ive tried boiling water before but limited success. I had to extend purge valve wires. Shrink wrap and solder only. Best way to fix wiring.
Discussion Starter #24
Because of the 95mm tb and mine being ripped off i made serious modifications to the timing cover. Here's the clearance pics. Still got to find a tb plug and fix it.
Discussion Starter #25
Had some time this evening to start the door. Will finish it tomorrow and get the last of the pics for it.
I feel lazy cuz I haven't even washed mine lol
But yours is coming along nicely
Discussion Starter #27
So when i bought the parts car('15) it had no key. Heres to show you only need the dealer for the 4 pin each car requires. Right tools and you can program them yourself.
Discussion Starter #28
So i finished the door last night. Drilled out the clip holes and installed new clips. Bottom screws lined up and all but one of the panel pin holes lined up. Drilled it out and heres the end result.
Discussion Starter #29
Ok so found some info for the 440. A jeep cam sensor with slight modifications will fit into the 440. Only problem is its a 1x count instead of 4x count that the vvt engines run. So looks like its headed in the right direction,just need to do a little more homework and figuring to get it 4x count.
Discussion Starter #30
Finally got a plug for the tb today. Had to buy an adapter cable because i couldn't find a plug anywhere. Cost 50.00 to get the plug. Little high in my opinion, but i needed one and this was only way i could find it. Have one major plug to fix left, Abs module.
Discussion Starter #31
So my buddy had a '15 charger thats parts,so cut the abs plug out of it and soldered it into the challenger today. Heres few pics of it. Video of it running coming very soon. Sounds great.
Discussion Starter #34
Heres some pics of finished abs harness. Thought i had already uploaded them. Heres video too. Spit out a code for improper voltage coming out of tb. Running rich and no time to fix it yet. Been fixing other cars and havent had time to mess with mine yet. Oops video is too long. Will cut it down then post.
Discussion Starter #39
Holidays have been killing my time and $$ but its time to get back to my project. Bought some suspension pieces and put them in today. Put springs and upper control arms in.
Discussion Starter #40
Heres how she looks with the suspension done. Put T-handle on shifter also few days ago. Had to modify shifter handle and extension to make it fit. Ordered few more parts today also.
21 - 40 of 59 Posts
