Hello. I thought I would sit down and write up everything that I can think of that I have done to my r/t. I was wanting to get some suggestions on what to do next. The obvious answers are probably supercharger. I wish I had the money for that right now but I don't. Any other ideas?
Here is what I have:
Comp Cams Hemi Phaser "274" Camshaft for VVT
Comp Cams Variable Cam Phase Limiter for VVT
Comp Cams Beehive Valve Springs
Long Tube Headers
High Flow Cats
Magnaflow Mufflers
DMH Performance Low Profile Electric Exhaust Cutouts
Diablo Sport Trinity Tuner
Jet Performance 180 Degree Thermostat
Cold Air Intake
Cold Fusion 125 shot Nitrous Kit W/ purge kit
SpeedLogix Oil Catch Can
BBK 90mm Throttle body
Eibach 1.5" lowering kit
Niche 20" Apex Wheels (8.5 fronts 10.5 rear)
Nitto Invo Tires (rear 295x35)
(other)
Black Billet Fuel Door
Black Billet Punisher Skull Emblem
5% tint all the way around
Integrated escort live radar detector(Awesome)
changed LEDS inside interior to red (cup holder, dash, door panel)
Made my own halo's (red 10kmcd leds)
Black Painted grille
Smoked Side Markers
Infinity Speakers
Nitrous Outlet Nitrous switch panel
Blow it!
Seriously though you have a lot of stuff that will help you get the most out of the boost pressure you'd use. I'd start saving up.
Front and rear strut bars from Razors Edge ... upgrade sway bars ..... sub frame connectors .... front and rear tension arms since your lowered I would definitely put on some sway bar end links and the rear tension arms will get rid of any wheel hop you have ..... with the extra power your going to need to plant it .....
