Wiring the Stock Head Unit
Taking the HU trim is pretty straight forward and has been discussed in several posts, I will only touch on the important points and relevant to my install.
Hints: Roll down your windows, go to the trunk and disconnect the negative battery terminal before you do anything else.
Again, using the trim kit tools I carefully pried of the bezel, there are 8 clips in total, 3 top, 3 bottom and 2 on each side. Once removed disconnected all the plugs for the AC controls (3 plugs on my car). Lay a towel over your console to protect it, set the bezel aside and start by removing the 4 #2 Phillip's screws from the HU. Once removed, you can pull and slide the HU straight out, do not force it and remember there are a couple of wire harnesses' connected in the back (pict 2). Once out, unplug all the connectors, antenna and Satellite plugs.
At this point I connected my new wiring harness **(PAC AOEM-CHR3 Integration Unit, Pict 1) to the main car harness and to the back of my Head Unit. Again I ran lengths of speaker wire and hooked them to the speaker outputs from the harness and ran them behind the HU and set them to the side (The beauty of this, is that you don't have to cut or alter your original harness Pict 3). I then connected all plugs, reinstalled the HU, and replaced the bezel.
**This is a two piece harness that has a 4 channel RCA audio output for adding aftermarket amplification. It also includes a switched power lead, which I also ran a length of wire and set to the side. I am using the Cleansweep so I just didn't use the converter and only used the harness section, this gave me the speaker outputs where I hooked my new speaker wires.
Next installment: Door and Rear Speakers. Stay tuned!
