1 - 20 of 22 Posts
The Unofficial MyGiG forum site.
The Unofficial MyGIG Information Site Forum • View topic - Link for software RER/REW/REP 2.402 - iPhone patch
Bug fixes:
iPhone4 compatibility issues
Intermittent no sound from audio system when using remote start
Radio lock up when using U-Connect
Repeated "acquiring signal" message when in satellite radio mode
Download 2.402:
http://www.mediafire.com/?84a1dbj587p70gv
The file is an ISO image file. All you have to do is burn the image to a CD and update.
I just finished the update and it does fix the iPhone OS 4 issues we were having.
Credit to GMoney for posting the fix.
http://www.challengertalk.com/forums/f39/iphone-4-bluetooth-fix-51767/
Does it do anything else? I have a Droid and if the Iphones all it fixes I won't upload it.
Change log edited in post #1.
Worked on mine!
Finally got off 1.295 for good it appears (had issues with all the others and kept going back) ... seems like all the issues with the iPhone 4 are now resolved <fingers crossed>.
The update worked perfect.
It changed my logos to the new Dodge logo, and removed the Ram's Head.
Fixed my connectivity issue with the iPhone 4.
My wife's iPhone 3GS worked perfect all along.
Make sure that you burn the disk at 2x, otherwise, it has a difficult time reading the media. Experienced this my first disk burn.
Once the update is done....
press the seekup - seekdown + nav buttons to eject the CD once it fully completes.
but thanks for the update, and info. :bigthumb:
Rayzazoo,
Thanks for the update.
The link/download & install worked perfectly.
I actually like the new Dodge splash screen instead of the ram's head.
Much appreaciated...
You must have had an old ver. of software. The goat head was gone in the last flash. I never had to use the other keys to eject the disc just the eject button. Mine did have errors updateing the HHD twice but I didn't burn mine at 2X.
yea, I was at 2.043.
You don't have to press those series of buttons to get the CD out, after the update finishes and it asks you if you want to update from 2.402 to 2.402 just hit the normal cd eject button and it'll come out. It takes about 15 seconds but it comes out no problem.
I burned mine at 6X, slowest my burner would do, I had no problems. Also I just hit the close/open and it ejected after answering no to updating to same version. Perhaps becuase I used a DVD and not a CD? Will these units read a CD?
Also is it normal to hit the close/open twice. On the first push the display slid down but I then had to push it again before the DVD ejected.
[edit]The update fixed the problem I had of not showing caller ID.[edit]
I only have to hit my eject button once but there is a delay before the disc comes out. I'm pretty sure I used a CD and not DVD on the upgrade.
I saw someone mention the new dodge screen logo in the update... (even previous update)
If you load this onto a Chrysler My Gig, will it change the Chrysler logo to the new Dodge logo?
Or does it know to check current model & keep the Chrysler logo, be it the old or new one?
Update worked great! Thanks for posting
I can't say but in my Charger I had a MOPAR NAVUS navigation system, which was a big mistake but that is a different story. Anyway, I was contemplating removing the thing from my car as the touch screen quit working. Which it did twice under warranty. I found a new on on ebay for a good price so I just replaced it. The one I bought was from a Chrysler 300 and the first time I powered it up it showed a Chrysler logo, but after a shut down and restart it showed the Ram's head. There was only one cable going to the thing which had two wires. I assumed it was just power and I was going to have to see the Chrysler logo every time I started, but apparently it read something from the bus in the car and changed it. So my guess is the radio would do the same.
New iPhone 4 users...don't celebrate just yet! I just got a new iPhone 4 (4.3 iOS) and had the dealer load the new patch 2.402 firmware into my 730N RER. Dodge website says 2.402 patch is compatiable with iOS 4.1 and 4.2...no menion of 4.3. Uconnect still says no number stored when attempting to call someone using the voice recognize feature and hangs up...it appears unconnect cannot store any phone numbers from iPhones with the latest 4.3 iOS software. Anyone know of a new patch that fixes this latest iPhone 4 software version compatibility? Ugh...dealer does not what to do. Someone told me to downgrade my iOS software on the iPhone to 4.2 through iTunes...not crazy about that. Thanks!
I have burned twice now and still cant install WTF
1 - 20 of 22 Posts
