1 - 3 of 3 Posts
Hey Guys, Hope this is the correct place to post this! If not, Sorry.
When i push the Uconnect button on my factory RER radio and the annoying lady comes on and says "choose one of the following" then she goes through the list, the screen converts to a map of my current location. When she is done, it will show the list again. Should the list stay on the screen as she is going through it? Thanks
Assuming you have the 2010 and older UConnect, I think it depends on what your 'default view' is set to.
You can hit the 'settings' button on the right side of the radio and select which view you want to set as the default. If 'MAP/NAV' view is selected the radio may assume you are trying to navigate somewhere and maybe they dont want to hide your map while the 'annoying lady' is rambling on (which can get quite lengthy depending on what screen she's reading off)
Without going out to my car and playing around with it I don't know for sure but you could try messing with those settings.
Remember you can always interrupt her by pressing the "voice command" button again while she's talking.
1 - 3 of 3 Posts
