1 - 20 of 20 Posts
Folks, I have a 2007 SRT Charger with the NAG1 tranny and the 3.06 Getrag gear. What is the expected engine RPM at 70MPH if I install the Getrag 3.73 gear? I want to know what tio expect if I install a SC 392 with the 3.73 gear to dterrmine engine longevity.
Thanks
I run 2800 at 70 mph and 3000 at 80 with 3.73's on 275/40/20's. The calculators are not taking into account for converter lockup efficiency.
If I remember right I run about 2100-ish. For an exact number I'm sure there are formulas on line for the calc's. Or, Eddie or Builder Bill could tell ya.
with 28" diameter tires in fifth gear you will be going 2600rpm to go 69.95mph
Man, I didn't think it was that high. I smooth out at about 1500-1700 and the exaust quiets down at about 2000 and that's around 65. I am running 315/35's, the 3/4 inch might make a difference.
I'm sure your right GSO. i haven't had her out for about 4 months.
It's higher even than GSO said. If you wanna know what it feels like drive around in 3rd on the highway.
Thanks
QUOTE=gsochallenger;702508]with 28" diameter tires in fifth gear you will be going 2600rpm to go 69.95mph[/QUOTE]
GSO is about spot on for my ride when I run the DR's and I've been running the 3.73's for over 2 years now!!
For Street and show I run a 285/40-22 (31" Diam) which brings the RPM down even more....But to tell ya...the 2500 isn't bad....my '01 Lexus Is300 runs about 2700 RPM at 70....I have 400,000 miles on the original car!
G
I used the stock converter, for now. In that regard i have "lock" sooner rather than later. Honestly there are a lot of things I'm looking forward to dialing in this coming spring/summer. Cooling, suspension, hook up, launch.... etc...
No you don't actually....they all "LOCK" at the same points.....this is not the same as stall. On a stock tune the converter doesn't actually lock 100% either and this is what I meant by percentage of lock up.
Got it. Good to know. Thanks
Discussion Starter #16
Thanks for all of the responses folks as this information will help me determine whether I will move to the 3.73 in the Charger. Appreciate the follow-up questions/comments. Clearly I have much to learn and the members of the forum are a wealth of knowledge.
Discussion Starter #18
You will have a 21.9% increase in rpm from your current readings.
Ok, there is a mathematical formula out there some where that allowed you to obtain this value. Can you provide the web site?
2009 R/T
I'm sure there is but it is just basic mathematics. 3.73 is 21.9% larger than 3.06. In reference to his query his engine will rev 21.9% more than it does now with all things being equal.
Discussion Starter #20
True but thought there may be a formula that includes effect of tire diameter on rpm. I should have been more clear in my question.
1 - 20 of 20 Posts
