1 - 2 of 2 Posts
I have an 08 SRT-8 with an STS twin turbo set up running 5 PSI. Last night I noticed oil being pushed out of the spark plug o rings. It has alot of positive crankcase pressure. It also blew the dipstick out of the tube. I'm going to do a compression check (just to be sure) and replace the PCV Valve ( just in case). Does anyone have any other ideas? Any good pics of crankcase ventalation setups?
Did you route the oil return into the breather port. And if so the motor can't breath. If that's the case you need to run it into the valve cover.
1 - 2 of 2 Posts
