1 - 2 of 2 Posts
Thanks for the add. Here is a problem that just started recently. When I first start my car whether in the morning or afternoon(cold start). If I don’t let it warm up and I put it in reverse or first gear(6spd manual) I get this shudder. Kind of feels like it is coming from the rear of the car. But if I let the car warm up for a bit , it shifts fine. I have a 2012 Challenger R/T 6spd manual. Only happens in first or reverse. If I start off in 2nd gear it seems not to happen. Any suggestions on what might be the issue or cause. All your advice is much appreciated.....
On a cold start you engine is idling at higher RPM’s so once your in first and trying to engage , its trying tongran and take off faster than you normally would causing that shudder (my guess)
1 - 2 of 2 Posts
