You really don't think I'll notice anything with the canned tunes? People said that the canned tunes remove the torque management and that makes the difference. Is that not true? That's the whole reason I bought this sucker.
You'll probably notice a slight improvement, it's just not going to be anything like what the automatic guys experience because the factory 91 tune is already pretty close to the canned 91 tune. Since you're also running the OEM t-stat you're going to still get hit by heat soak/temp related timing loss, IMO.
With the canned tune and 180 t-stat the power was more consistent across varying ambient temps and I no longer felt like 75+ temps were costing me 100HP.
Then I went with a custom email tune including sending data logs after the initial custom tune and that made the biggest difference, felt a lot stronger across the entire RPM range and I'm seeing no more LT KR than before (Max of 1-2 when under load at cruising RPMs, 0 the rest of the time).
I'm just trying to set your expectations a little lower since you have a 6-speed, if it ends up making a big difference for you then that's awesome and you'll appreciate it, but if you're expecting a life-changing experience and it doesn't happen then you're going to be disappointed. At least until you get a custom tune.
