1 - 4 of 4 Posts
Attempted to install that POS "No-Drill" Aero Plate License Plate Bracket today.
After disassembling the bottom of car...fitting bracket arms thru plastic grill...torquing the near impossible miniscule set screws....I find it's impossible to fit a drill under the bumper brace. I got a dremel with 1/8" bit...even that doesn't fit...so I started drilling it at a slight angle. Doesn't seem to be penetrating the metal brace more than a dimple. Any advise on how to drill the 2 holes so I could put my car back together & drive?!!:disgust:
If the bit is walking around, you need to center punch a dimple to start your drill. and it sounds like you have a dull bit. If you have to buy bits, get pilot points.
Good luck, Greg
Good luck, Greg
did center punch before i started. i'll try the pilot point. thanks!
1 - 4 of 4 Posts
