It should work...do you have an auto or 6 speed.
Also, depending how much modification the prior owner did, you may need to do some modification to ditch the horrible aftercooler on that GSM system, as well as the piggy back ECU if it still has one among other things. I would only jump on it if it is REALLy cheap, as there will be some work involved to get ot up and running safely on your car.
What does "everything" include. Does it have an air to air interccoler or the horrible GSM aftercooler. Price would depend on how much $$ you would need to put into it to get it running correctly.
· Banned
Depending on the condition I wouldnt pay more then $1800.00 or so. To do it right figure on another 2-2.5k in getting it to work properly.
Now let me say this.When this kit is set up properly it is a very nice kit. And can make mad power if need be. I did a kit not to long ago he made 610rwhp on pump gas And went 10.7 in the 1/4 And this was on a charger..
Things you will need..
Front mount Air to air
injectors
bap
misc plumbing couplers
upgraded fuel line from the tank to the Pump. Im sure speedlogix can help you get what you need to make it work
injectors
bap
X2
::werd::bigthumb:
