1 - 4 of 4 Posts
So I just ordered a set of 20x9 rims for the front and I am comfortable with the tires I am going to put on the front. The back ones are 20x10.5 and I am looking for advice on tire sizes. I have a 2017 challenger rt 6 speed with the eibach sportline lowering springs. Would a 275/45/20 tire fit or would I need to go wider. Thanks I’m advance for any help.
https://www.budnik.com/helpful-tire-info
A Good reference. I'd think you'd want to go 275/40/20 to keep size similar to stock if you go 275. As you can see from the chart, you can go as wide as 315/35/20 if the particular tires don't rub.
285, 295, or 305 all choices, but they will not match exactly the diameter of stock.
https://tiresize.com/comparison/
What size are going on the 9"?
On the 20x9 for the front I think I am going to stick with stock. 245. It fits the fender will really nice. But the back does have a little more fenderwell showing than the front does and I wouldn’t mind filling it in a little more.
2014 Dodge Challenger
I have 20x12 wheels on the rear of mine with 315's and it definitely takes all of the fender and then some... but no rubbing
I kept the 245's on front.
1 - 4 of 4 Posts
