1 - 4 of 4 Posts
Hi, I removed my MFER-1's from my exhaust and trying to put the OEM active exhaust actuators back on with the spring. The issue is that the spring doesn't not currently align with the two notches inside the muffler pipe. How do I get the spring to realign with the two notches? Any help would be greatly appreciated.
Sent from my Pixel 4a using Tapatalk
Just turn the notches on the valves to wherever they line up, with the actuators connected the PCM will cycle the actuators full open and closed when the engine is started.
Thank you for the timely response. This was extremely helpful.
Tighten the nuts evenly. As in if you give one nut a full turn, give the other 2 a full turn next.
1 - 4 of 4 Posts
