1 - 2 of 2 Posts
Is there enough room after the pads have been removed to remove the disc's in the front calipers w/o removing the star bolts thereby splitting the calipers? If not, where can I buy the tool that will not damage the paint on the bolts?
Don't touch the star bolts(inverted TORX bolts).There should be two bolts on the back of the caliper that attach it to the knuckle.You need to remove the caliper to get the rotor off.
1 - 2 of 2 Posts
