I have a 09 R/T and my front bumber has been damaged by a shopping cart or who knows what. Anyway instead of replacing it with another 08-10 style bumper I wanna change it to a 11-up style. It's cheaper and looks better to me. My only confusion is with the fogs. Do the 11+ use a different housing and bulb than the 08-10? The reason I ask is mine are Looking worn so I thought I'd just replace them while I'm at it
It is a different housing and the plug is also different.
Discussion Starter · #4 ·
Alright so the housing should be slightly different. That's what I needed to know. Now gotta find the part # for the 08-10 housings. From what I read they both mount to the bumper the same
Discussion Starter · #5 ·
Upon further investigation sounds like the housing is the same but the bulb and wiring is different. Sound right?
Supporting Vendors
The housing might appear the same, but the bulb is different and will have a different socket. I'm fairly certain they are model year specific, but if the mounts are the same it won't make a difference, you can use either bulb and wire it up
Nick C.
You're better off with your 2010 style housings, the 2011+ PSX24W bulbs are crap.
